Re: Winter preheat
I use a one burner campstove(5000BTU),it will burn for two hours + on low. I have about three feet of rigid ducting. The last two feet is three inch. I can get my hand only within five inches of the outlet with out it becoming unbearably hot. this a good test when deciding how close to the oil sump that I place the duct. I generally drain the oil into a 0ne gallon metal hydraulic fluid can which I can leave on a wood stove over night or a burner on low for thirty minutes or so. I make sure the oil does not boil. The Quick- read thermometer shows about 170 degrees. I also have a quality engine cover to contain the heat. The hot oil cuts quite a bit of time off the preheat.
Jim
Jim
