On the rear of my lower jury strut strap mounts I notice that they can slide on the lift strut about a 0.50" either side of center with little force. Is this normal or should I fabricate new straps that are tighter?
lower jury strut mounting strap question
DJ Vegh
www.azchoppercam.com
www.aerialsphere.com
Mesa, AZTags: None
Re: lower jury strut mounting strap question
the jury strut clamps do not have to fit tight to the strut. Use wraps of Industrial white tape, usually about 3/4 wide and usually takes about 1 1/2 to 2 1/2 wraps....Taylorcraft Foundation, Inc
[email protected]
thanks. I think I'll try the white tape. sounds reasonable.DJ Vegh
Mesa, AZ
3M "Microfoam" tape is very thin but provides some cushion. Mine has this tape installed on the inside of the strap, then razor trimmed flush with the edges of the strap. When installed, you can hardly see that there is anything there.Taylorcraft : Making Better Aviators for 75 Years... and Counting
I've used a product called "Stone guard" from a body shop. It's a heavy clear plastic material, nearly invisible when in place.
DJ,
I might have missed the post, but I take it she got home alright??? My former BC-12D had a couple wraps of white tape around the strut. Have fun!!!Cheers,
Originally posted by M Towsley View PostDJ,
I might have missed the post, but I take it she got home alright???DJ Vegh
Mesa, AZ
Do not use PLASTIC tape, ( the black electric type) I have seen rust under it rot right through the strutI think I'll have another BEER , make some big decisions, watch The Unit and go to bed!!
I did get 21 slides done for the NEW Power point presentation
Taylorcraft, the War Years 1942 thru 1945. and some other research today. WINTER IS IN OHIO!Taylorcraft Foundation, Inc
[email protected]
Forrest... what is "Industrial" white tape? is it a cloth based tape?DJ Vegh
Mesa, AZ
Yes cloth based, I could not find my roll today . Very porous and wider than the jury clamps.Taylorcraft Foundation, Inc
[email protected]
I have an idea... what do you guys think about using the rubber channel from an Adel clamp on the jury strut clamps?? It should not hold water or cause corrosion, but it will also cushion the clamp.Taylorcraft : Making Better Aviators for 75 Years... and Counting
If the clamps,& struts are held to a tight dimension this could work. The tape allowed for varience upon assembly , we used at least 1 1/2 wraps, thick on bottom or up to 3 1/2 to take up varience.... Then the touch up guy used strut color on the tape with a brush, looked good for a while.Taylorcraft Foundation, Inc
[email protected]
