Re: !)$(^@ FAA SOB's Trying to Shut My 337 down!
The 5 minute epoxy I used (actually 15 minute epoxy) was tested to an ASTM standard, having well over 1500 PSI in a "lap shear" strength test. I figure that if you only achieved one THIRD of that strength in actual shop practice, the glue is still good for 500+ pounds.
The screws will pull out of those wooden blocks LONG before this epoxy fails in shear. One of the engineers I spoke with briefly said that this was the part about my installation he did not like, because over time the screws want to pull out of the wood. True enough, but there has to be a load on the screws to make that appen.
My rough calculations show that there is very little load on the screws, something like 15 pounds each or less.
I am aware of at lest one aircraft and probably several others, that were certified by a governmental agency as airworthy, that used wood screws to hold windows into wooden frames. The British Auster that I owned had a million little brass wood screws holding some of the windows in. I suspect many other pre-WW2 airplanes used brass wood screws to hold a lot of secondary structure together.
