Hi Folks,
I am getting the bird annualed. My IA is concerned about my carb dripping fuel while the plane is setting. When I did the recover-refurb three years ago I put a steel needle in the stromberg carb ( With help from an A&P). I was talking with a friend and he says it is hard to keep the steel needle from leaking a bit of fuel (metal against metal).
The carb had the derlin needle in it when we replaced it(not neopreme), but I went ahead and put the steel one in anyway. I have the auto gas STC.
I have been flying like this and the engine runs fine at all power settings, I just make sure I shut the fuel off at the end of every flight. My IA says I might want to think about getting the carb overhauled, but will this solve the problem? I have owned the plane for ten years and as I recall it dripped fuel even with the derlin needle, but maybe not as noticible as with the steel needle.
Any insight would be greatly appreciated. I have no qualms about getting the carb overhauled if it would solve the leak or if this is a saftey issue that must be addressed.
This is a c-85 12F
Thanks a bunch
Wade
This is a c-85 12F
Thanks a bunch
Wade
