fuel seal
  • fuel seal
    I need a place to get a main fuel tank seal the one thats around the neck and
    cowl. Thanks for your time.
    Re: fuel seal
    Univair do them, about $9 as I recall.
    You might need to trim it a bit with an Exacto knife.
      Re: fuel seal
      I need to make gaskets for the fuel caps on the wing tanks, any suggestions for the materail.
      I have tryed leather. papergasket,natrual rubber.
      They hold for a while and when they leak, shrink or expand.
      Len
        Re: fuel seal
        Thanks for the infor. len you might try sheet cork and use a little grease to
        lube it till forms .
          Re: fuel seal
          Some where I saw a note to purchase a sink plunger from the hardware store,cut and trim it to fit, the material is compatible with gasoline. Test it before you spend much time fitting the seal.
          Walter Hake TF#
            Re: fuel seal
            Len,
            Chief Aircraft has them, they are white and are listed in an obscure corner of a page. I think they list them as Cessna gas cap gaskets. Two sizes, measure yours as I cannot remember right now which ones they were. Fit all the gas caps perfectly.
              Re: fuel seal
              Viton is the material of choice today.
              What size are they? I have viton gaskets 2 1/4 OD, 1 1/2 ID and 1/8 thick for $3.50 (Ercoupe parts). Also a few neoprene (AvGas only) on closeout for $1.00
              I also have a giant grommet that goes around the tank neck on an Ercoupe. It's about $10, IIRC
              New Yoke hub covers
              www.skyportservices.net
