My plane is a 41 BC12-65. The control yokes are the banjo type. The shafts are nickle plated. The shafts are worn and are in need of replating or replacement. The factory has nickel plated shafts but they don't come with the required welded flange and they are about a 1/2 shorter then mine. My questions are, where can I find the proper yoke shaft with the flange or should I get the originals replated. If I go the replating route do I need heat treating for embrittlement. Thanks in advance for the help.
Norm G
Norm G
