"doesn't matter if they used ZC or red oxide. after this time, if no rust on the surface then it obviously worked" - My A&P
FOLO: The red oxide question
Re: FOLO: The red oxide question
Originally posted by Robert LeesRed oxide primer is rust-coloured. Visually, can you easily tell it's not rusting underneath?
I used to use red oxide primer on cars....it worked a treat, but then I wasn't having to comply with FAA regs, and I wasn't gluing fabric to them.Mike Horowitz
Hello: Just a historical note...my logbook for my '46 BC12-D contains an entry that it was recovered in 1958 after the fuselage was coated with "red lead". I am removing "green" coating from the fuselage now and finding light surface rust in dependent and aft surfaces. After sandblasting, I will coat it with a "white" 2 part epoxy just to see if rust breaks through! DocDoc TF #680
Assend Dragon Aviation
FAA Senior AME #20969
EAA TC #5453 / FA #1905
CAF Life Member #2782
"Leben ohne Reue"
