Re: Spray gun bargain
Compressor and their efficiency.
Just a hint as electricity is expensive.
A compressor is generaly not efficent than it has to produce a high pressure.
The reason being by pass in piston rings etc. If you run the compressor 100psi and only need 40psi for the gun and the compressor can keep up the volymetric demaned at 60 Psi., run it 60 Psi. If you are using a inpact gun it need 100 psi or more to do any good work.
Match the tool air requierment in SCFM's (Standard Cubic Feet Minute) with the compressor out put as close as is possible and you have " fuel-efficent system".
How do I adjust the pressure? On the pressure swithc is one or two adjutment in form of a screws. One set the max pressure.
The second screw adjust the range between starting and stoping.
Use a good liquivid filled pressure gauge, it pays in the long run.
Len
Len
). Any style of gun can achieve excellent results IF you use them properly. I'm as guilty as anyone of trying to paint the same way with every gun... but if you really sit down and learn about the gun and what it does and why, they will almost all work just fine! Each has it's own idiosyncracies and traits... and it's up to us to find the one that fits us best!
