Does anyone have the dust covers for shinn brakes for a 1946 Taylorcraft BC12D
Dust. Overs of a 1946 Taylorcraft BC12D
The only source was Skybound and it's not clear (to me anyway) what happened to any remaining inventory.
I toyed with the idea of making some using a plywood buck which wouldn't be too difficult to make, but was able to buy a pair from skybound. That was about 10-12 years ago.
SScott
They can be made with soft aluminum but you will need to do a LOT of metal bumping to make them. I have repaired some REALLY bent up ones and it is a bit easier than making them from scratch. They don't look perfect when finished, but you have to lay down under the plane to see the flaws. Also takes a while to eliminate and contact between the wheel and dust cover. The first time I turned the wheel the scraping sound was a real shock. Took about a half hour to gently work the 124465418_10103233834816084_1832340409896912128_n.jpg Shinn brake dust covers.jpg edge to eliminate it.Originally posted by Scott View PostThe only source was Skybound and it's not clear (to me anyway) what happened to any remaining inventory.
S
