OLD plastic on aluminum
  • OLD plastic on aluminum
    Any one know how to get old and brittle plastic off of aluminum. It will not pull off in sheets.
    BL
    I don't think I understand. What old & brittle plastic off which aluminum? I'm sure I'm missing the obvious.
      When you buy aluminum sheets, sometimes it comes with plastic sheeting adhered to it for protection. I was given some very old aluminum sheet that I can’t get that protective plastic off short of sanding it off.
      BL
        OK now I understand. Ask the Vans RV guys. An old 2006 post shows this:
        At our builder's group Thursday night I demonstrated how to remove the plastic from the skins the easy way. Everybody was impressed & you should have seen the jaws drop when they saw how easy it is. Peel back about an inch of plastic. Tape that plastic to a pipe, broomstick, or whatever you...
          I have used heat to help. You might also try some paint and adhesive remover. Once you get to the point it breaks instead of stretching a little it becomes problematic.
            Tried heat no good, same with lacquer thinner. This stuff isn’t the heavy blue stuff, it almost as light as cling rap.
            BL
