Cabin Heat Valve
  • Cabin Heat Valve
    Well, here is a some what a unique issue!!!
    It seems my "Florida Taylorcraft" never had a cabin heat valve installed on the firewall during some past rebuild
    Is there anyone here that has one? Does anyone know where to purchase one?? Is there a previous 337 installing one that can be used for directions and as accepted data??
    Any input is appreciated
    Craig
    No need for a 337, the aircraft came certified with the heat valve installed, so you're simply reinstalling a part that's suppose to be there.
    https://3.bp.blogspot.com/-rFRkuFsvC...0/DSCN6868.JPG
    Most of the valves are worn from rattling around for years, but can be repaired by welding.
    I made a doubler with nutplates that goes on the aft side of the firewall so that the valve and lower cowl mount is held in place by structural machine screws in ace of rivets. Makes it a one man R&I
    S
      Thanks for Pic Scott
        Message me. I may be able to help you.
        Bob Picard
        Bob Picard
        N48923 L-2B Skis/Wheels
        Anchor Point, Alaska TF#254
