Fuel shutoff valve connection to cable
  • Scott
    replied
    This photo shows the psh/pull tube, which is threaded. The knob is attached to a rod which is threaded and forms the male. The nut locks it in place. I think it's 10-32.
    S
  • Bruce Caldwell
    replied
    Thanks Woody! My valve has that pin on it but I didn't know there was a spring. What I'm not sure about is the other end. I don't have the original cable so I'll have to fabricate something. Thanks again!
  • Woody
    replied
    It is a steel pin brazed on the handle.
  • taylorukuk
    replied
  • Bruce Caldwell
    replied
    To ragwing nut, I'll send you a pm
  • Bruce Caldwell
    replied
    That helps, but do you have a closer shot of how the rod attaches to the handle? Thanks!!!
  • taylorukuk
    replied
  • Woody
    replied
    You can fix the internal leak by using fine valve grinding compound and lapping the cone to seat.
  • Scott
    replied
    For what? no orings were used int he original installation...it was a leather packing..
    That's likely why they leaked! The MS29513 (I can never remember the dash number) O ring however fits perfectly and is a good solution to the external leak issue. Internal leaks, a different story.
  • Woody
    replied
    Drill a 3/16" hole and insert clevis pin. If you want you can braze the pin to handle.
  • Bruce Caldwell
    replied
    This is for a 46 BC-12D. Thanks for the input so far. I like the threaded shaft but not sure how to attach it to the valve handle.
  • Ragwing nut
    replied
    its a rod that attaches to a modified valve handle. etuscheon in the panel that it passes through. I have shut off rods if you need one.
  • taylorukuk
    replied
    Ours has quarter turn restrictor, spring, washer and "o" ring - Same main tank valve as every picture I have seen on this forum!
  • astjp2
    replied
    Originally posted by taylorukuk View Post
    Unfortunately this drawing isnt very clear. Just rebuilt our fuel valve and awaiting a new o ring to complete (MS29513 - 011 I think) fuel tank.JPG
  • Mike S
    replied
    Here's the fuel valve end:
