I searched and wasn't able to come up with anything, and hope someone can help. I'm looking for a set of drawings/dimensions for the steps some Taylorcrafts have. A friend on mine had a set on his, and I liked using them. Regretfully, he has since sold the aircraft, and I never used them as a pattern to make my own. Any help would be appreciated!
Step drawings for 46 BC12-D
Here's some examples from Wag-Aero: https://www.wagaero.com/catalogsearc...ylorcraft+step
aa140l_1.pngaa140r_1.pngN36007 1941 BF12-65 STC'd as BC12D-4-85
I brought the steps from the 45 home tonight and they are on the kitchen counter. It was in the mid to high 90s today and the hangar was almost warmed up enough to bake french fry's. Even with both sides open I could only spend about 15 minutes hunting for any extras. Makes me worry about the impact on our planes to be stored in that kind of heat! I was working on a design for a blower to be mounted on the ceiling and a duct to push the hottest air out. The airport won't let us put a wind turbine on the roof if it penetrates the roof. This would blow out through the gap above the door. Need to make it run on a solar panel but it needs some pretty good protection from catching fire. Better a wind turbine hole than a burned down hangar row!
I will see if I can make some sketches of the steps so they can be copied.
