Safety cables and shoulder harnesses for an L-2?
  • astjp2
    replied
    Originally posted by sully View Post
    Attached to a welded tab on upper structure.
    Click image for larger version Name:	20190513_132015.jpg Views:	2 Size:	123.1 KB ID:	182677Click image for larger version Name:	20190513_131958.jpg Views:	3 Size:	131.6 KB ID:	182678
    that welded tap would have to have a 337, if you just wrap the harness around the tube, its a logbook. that depends on if that tab is original, if not, it needs paperwork because it was welded.
  • sully
    replied
  • Guest
    Guest replied
    Tim, Ryan,
    They are Piper cables that I see in the link.
    But I am wondering if in fact L2's had or even needed safety cables.
    Isn't the bungee assembly extension mechanically limited by the way it's made?
    Or am I remembering it wrong?
    I only worked on a handful of them.
  • astjp2
    replied
    Originally posted by RyanShort1 View Post
    So I found out where the safety cables we had on the old Taylorcraft I used to fly were from: http://www.fadodge.com/safety-cables-for-mlg-std/ but I need to figure out how they did the approval for them. Wonder if they 337d it or had some sort of field approval?
    Why do you need approval for those? Just put them on and fly it. It is normal equipment.
  • astjp2
    replied
    Originally posted by n6346m View Post
    Ryan,
    I'll try to take some pictures of my installation. It attaches to the seat frame. No tools needed to install. Mine came with the airplane for the front seat only. My airplane doesn't have a swivel back seat, it had been replaced by using another front seat. I had a matching harness made for that seat as well and it was pretty easy and inexpensive, If you have the swivel seat I don't know if what I have will work for it.
    Bob Picard
    N48923 Taylorcraft L-2B Skis/Wheels
    Anchor Point, Alaska
    Are they mounted above your shoulders? If not you need to move them. If you get in a wreck and they are too low, you will get spinal compression.
  • RyanShort1
    replied
  • n6346m
    replied
    Ryan,
    Bob Picard
  • RyanShort1
    replied
    Originally posted by lawheelock View Post
    There is an FAA letter issued a few years ago which allows the installation of shoulder harnesses in older aircraft without much more than a log book entry under the FAA's philosophy that safety enhancing equipment should be encouraged without the requirement of massive paperwork.
    I have a copy of that letter in my computer files, but am unable to find it this evening. Perhaps other responders will be able to provide you a copy.
    Larry Wheelock BC12D and Stinson 108 and Mooney M20C
    I'm familiar with the letter. Guess I'm more interested in what folks have chosen to install...
  • lawheelock
    replied
  • Safety cables and shoulder harnesses for an L-2?
    I've seen safety cables on the landing gear of an L-2 before but don't know what paperwork was needed or where they came from. I'm also looking to install some shoulder harnesses on an L-2A. If you have information on either of these, please let me know where to look!
