I just pulled the tailsprings and tailwheel off my BC12D. The springs are rusty and pitted (where the grease did not go) so those will be replaced, and the tailwheel is a Cessna part that is quite sloppy, also finding its way to a dark corner of my hangar, for now.
Scott 3200s seem to be the go-to choice and have a good reputation, but at a $1000 a crack (maybe 2/3rds that on ebay .. and I'm wary of buying used) I want to investigate other options.
I'm new to taildraggers (helicopter pilot) but I would think a wider footprint in the back would help with steering and ground maneuvering --off pavement anyway, where I'd like to do at least half of my flying. Even the wet sod and gravel around my hangar allows the tailwheel to dig in.
Has anyone had success using a wider tire in the back?
Looking forward to your opinions and suggestions.
Edit: After a bit more cleaning up, I see my "Cessna" tailwheel is really a Scott 3000 (I think) with a Cessna nameplate tacked on the fork.
Edit again (if anyone is still listening
): It's a Scott 3-24
