Hi, restoring N95132 hasn't flown since 1964. I've always had Aeroncas never a Taylorcraft before and no one in the area to look at.....my Taylorcraft has field approved Piper PA-20 seats in it...want to install original sling seat to save weight. Can I get pictures of how the sling seat attaches to the tubing, how is the seat tied off in baggage area where it forms the 90 degree angle to transition from seat to backrest? where seat belts are bolted to and how the front of the sling seat is attached to the forward crossmember where landing gear bungees are attached? Thanks
Seat Sling/Seatbelts
Re: Seat Sling/Seatbelts
here you go:
More pics and some tips here (you'll need to scroll way down to "October 2015"):
TALORCRAFT Taylorcraft BC12D aircraft restoration maintenance fabric sheet metal paint airplane repair wing aileron fuselage cowling A65 PA 18 super
I'd say the two most easy traps are a. mixing up the left and right side rods and b. not putting the seat-belt attach rings around the tube. Better explanation with the pics
SScott
