Does anyone, know of an STC, or any kind of approved way to Cut the nose cowl, so the Prop, won't have to be remove, to remove the Nose bowl, part of the cowling?, Thank You, Don
WSplit Cowl
Re: WSplit Cowl
We have to read and digest part 1 and part 43-A. A superficial reading of each alone will result in two different answers about what is a major alt.
Taking part 43 alone will have one conclude that any change to a fairing is a major alt. But taking part 1 and 43-A together can lead to a it a different conclusion.
From part 1;
Major alteration means an alteration not listed in the aircraft, aircraft engine, or propeller specifications�
(1) That might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or
(2) That is not done according to accepted practices or cannot be done by elementary operations.
from part 43 appendix A;
(a) Major alterations�(1) Airframe major alterations. Alterations of the following parts and alterations of the following types, when not listed in the aircraft specifications issued by the FAA, are airframe major alterations:
(i) Wings.
(ii) Tail surfaces.
(iii) Fuselage.
(iv) Engine mounts.
(v) Control system.
(vi) Landing gear.
(vii) Hull or floats.
(viii) Elements of an airframe including spars, ribs, fittings, shock absorbers, bracing, cowling, fairings, and balance weights.
(ix) Hydraulic and electrical actuating system of components.
(x) Rotor blades.
(xi) Changes to the empty weight or empty balance which result in an increase in the maximum certificated weight or center of gravity limits of the aircraft.
(xii) Changes to the basic design of the fuel, oil, cooling, heating, cabin pressurization, electrical, hydraulic, de-icing, or exhaust systems.
(xiii) Changes to the wing or to fixed or movable control surfaces which affect flutter and vibration characteristics.
Re: WSplit Cowl
Hi Dave,
I understand your point, but there would not be a discussion if it were not for someone who apparently needs constant access to the front of the engine. I am curious as to why. I cannot even remember the last time I pulled the nose bowl.Cheers,
Re: WSplit Cowl
Originally posted by PA1195 View PostIn my experience a prop removal and reinstallation takes very little time on a Taylorcraft...safety wiring being the longest procedure. I'd guess less than 1/2 hour total.
Tim, you are always a conversation promoter, lol.Cheers,
Re: WSplit Cowl
Well lets see, the change does not affect weight and balance (less than half pound), cooling or aerodynamics....Its non structural, soft aluminum, so I don't see a problem, but I find that a 6 ply tire is a change to the type certificate and a major...TimN29787
