Is there a retail source of wing tank fuel valve placards?
  • Is there a retail source of wing tank fuel valve placards?
    Is there a place to go to simply purchase wing tank fuel valve placards?
    Not interested in making them just want to purchase some, anyone know of a place to purchase them?
    Thanks, Dave.
    Re: Is there a retail source of wing tank fuel valve placards?
    I have had good luck with this company over the years. Just let Dennis know what you want made.
      If you know exactly which placard you need (photo) and I have one, I would be glad to loan it to them to copy.
        Hi all,
        I am having wing tank placards made for my BC12D.
        They will be copies of the ones that I purchased Dorothy Ferris Taylorcraft in the '80s., a scan with size is attached.
        The text will likely be black and the background a silvery gray as the originals were.
        I have to buy 48 of them and I plan to do that. They will be vinyl, outdoor sign quality, mat finish, sticky back.
        I think that I can get a mix of colors within the 48. For example black text/gray background on 12 of them and black text/ tan background on 12 then red text/tan background on 12...
        If you are interested in some let me know. Will cost about $1 each plus postage.
          Hi Dave,
          I will take four of them in the original color as indicated, (black with silver/grey background). If others are in serious need you can cut that back to two.
          Curious, are you using a local company or did you outsource? You can PM me if you don't want to share online. Thanks!
            Hi Dave,
            Local company called Signarama.
              I'm in for 4, original colors. I'll send you some $, what address?
              Garry
                I'd like to get 2, it seems like I got one from Forrest long ago that was made of soft brass, or some metal like that, but after several disasters, I don't think I have it any longer, let me know and address to pay to, gary
                  I expected to be called to look at the proof copy of the text and boundary lines on Thursday but we are going to get snow so that will delay it I bet.
                  Should be giving them ok to print and cut them on Friday or Monday I suppose and will post the info at that time.
                    I will take 4 of the original backgrounds if possible. Thanks!
                    Dustin Blevens
                    Paragould,Arkansas
                      Hi Dave, I will take two of the original background as well.
                      Thanks
                      Ryan Newell
                      1946 BC12D NC43754
                      1953 15A N23JW
                      TF#897
                        I would like 2 also, keep posted Thanks
                          Dave, I would like two also.
                          Jerry Lane
                            Count so far;
                            Marty 4
                            Garry 4
                            Gary 2
                            Dustin 4
                            Ryan 2
                            Walter 2
                            Jerry 2
                            Total=> 20 + my 2 is 22
                              The brass placards are the early ones used before and just after WW-II. Josh made some and had a method worked out but we lost the tooling and manufacture method when we lost him.
