Re: Carbon & Exhaust Valve
Thanks again for all your comments and info. To answer a question, It appeared my AI did much of what you describe above. His little kit included rope which he put inside the cylinder as he had me slowly turn the prop in various direction. Then there was an adapter of sorts that screwed where the spark plug goes. It was adjustable with a pivoting head and he would put various tools and picks through it and would turn it. Several of the AP AI gathered around to watch because as he said, "we are going old school now" and they wanted to see. He mostly whistled happily once in awhile saying, "that's good, feels right, oh guide is clean and smooth, there it goes got it now, compression should be in 70's now". Some of the carbon came out with the tool. Wish i had got a picture or video of it, but I was too nervous to watch much.
I've flown it three hours since at higher rpm and did compression check yesterday, all still in high 70's. Per Hank's suggestion I got one of those infared thermometers and checked the cylinder temps after 2 hours of running hard. Granted it was after shut the plane down, but valve covers were 180 degree range with the front cylinders about 10 to 15 degrees less, if measure the cylinder near spark plug around 260 with front cylinders 15 degrees less.
Per comments/advice from here, now don't idle as much after startup but get in the air quicker, before shut down, let it run for one minute at 1000 rpm and then kill the mags, and store it with oil filler cap open and off to the side.
