When it move the wing tip up and down I hear clunk-clunk at the spar attach. The torque tube moves up and down....anyone have this happen? It must be loose in the spar and holes are probably getting oblong.
Strut attach fittings. Clunk-clunk
Re: Strut attach fittings. Clunk-clunk
Originally posted by Dano"T" View PostWhen it move the wing tip up and down I hear clunk-clunk at the spar attach. The torque tube moves up and down....anyone have this happen? It must be loose in the spar and holes are probably getting oblong.
I have not seen an issue with where you describe, but I have seen a issue at the fuselage strut attach point that will go clunk clunk when lifting the wingtip. The bolt hole becomes elongated in the webs on the strut attach fitting. This elongation is more common in the webs for the front strut.Last edited by 3Dreaming; 04-17-2015, 07:21.
Oops...compression strut, I will be cutting two new inspection rings and trying to pinpoint the trouble. It is definitely the fitting moving in the spar....either it's loose and now the holes in the wood have oblonged or god forbid the spar is cracked. The next step will be removing the wings and cutting a nice area open to get a good visual and make room for repairs. I hope it doesn't come down to an entire wing rebuild.
I remember at a Tcraft flyin years ago Forrest giving a demonstration on this and he lead to believe that it is usually a cracked spar. I hope its nothing serious and you can get back in the air soon.A&P/IA
Commercial ASEL/Instrument
N96999 '46 Taylorcraft BC-12D
N91467 Corvair Pietenpol
TF#1110 prev TF # 16
http://vansflyingservices.com
Cracked spars...both front spars just inboard off the attach fittings fear not ... I have a spare set complete with beefed up Harer STC mods....swaperooo and I'll rebuild at my leisure. Having 4 taylorcraft (2 pre war and 2 46's) I will have to take the wings off my flying bc12d on wheels for this...but I can just fly my cub .....it's on wheels too!
Dano... Too bad you have this problem to deal with.
But Thank God you found it through routine pre-flight type of inspection.... and not the worse way. Thank you for sharing this and thank you for for giving us all an example of how important is to "KNOW" your airplane, and its quirks and especially the sounds of trouble. Things that go "clunk" must surely be checked out.
Now... I am being nosey.... was there any one incident or occurrence that may have caused this? .... groundloop... high speed pullup... aerobatics??? Not trying to put you on the spot. But just thought it might help others to know... in the interest of safety.
Best wishes for your repair and re-work efforts.Terry Bowden, formerly TF # 351
[email protected]
Last fall I was on Lake Superior ... The wind started to pick up so I hurriedly took off....I was in a remote location so I probably pushed it by taking off in more chop than I would have....i put the plane away right after that and did not inspect it until now so I can't be sure....but i hit one wave hard enough that I cringed....bet that did it.
Originally posted by Dano"T" View PostLast fall I was on Lake Superior ... The wind started to pick up so I hurriedly took off....I was in a remote location so I probably pushed it by taking off in more chop than I would have....i put the plane away right after that and did not inspect it until now so I can't be sure....but i hit one wave hard enough that I cringed....bet that did it.
If the g-load from the waves was enough to bend the spar and cause a compression fracture (?), but you'd think the wing would be lifting by then from the wind and the fuselage and float fittings would have suffered some deformation as well.
Was the crack on top or bottom of the spars? Might post a pic so we can look for that type and area.
Can you discount any previous damage from snow loads? Like always hangared? Was born in Escanaba and lived in the Soo. Saw lots of snow as a kid in the '50's. Probably still does it.
DanoT,
Do the cracked wings have tube installed between the front and rear life strut attach fittings just above the lift strut attach point?
There should be a tube installed there and it has a long wire with threads on the ends that goes thru it and hold it in place as well as keeping the strut attach fittings pressed up against it.
