Engine Baffling
  • Engine Baffling
    I'm in the process of installing a re-built Cont. A65 which has Millennium cylinders. When I went to install the baffling (original style I believe) it would not fit. I can see now that the problem is the difference in the fins around the exhaust port. Has anybody had this problem and how did they solve it? Any suggestions would be appreciated before I start cutting things up and make things worst.
    Jerry
    Re: Engine Baffling
    I wound up building new baffling, I have ECI cylinders which are similar. Tim
      Re: Engine Baffling
      Tim- Do you have any photos of your baffling?
        Re: Engine Baffling
        I can maybe get some tomorrow, its basically a Cessna 150 back piece and then I added some material to my existing baffling and then made a few new pieces....Tim
          Re: Engine Baffling
          Air forms in Ak
            Re: Engine Baffling
            Chuck- Thanks for the photos. I can see from the second photo that the baffle has a jog in it on the right side where the exhaust fins are. That is one reason mine does not fit. The photo of the baffles don't show inter-cylinder baffles.... are you using them? Did you modify the baffles you received from Airforms?
            Jerry
              Re: Engine Baffling
              Jerry,
              I don't think that AirForms makes baffles for A65. I bought theirs for my C85-12 and they fit perfectly without modification. They include inter-cylinder baffles.
              I'm quite certain that Chuck also has a C85.
              Tim
              Tim Hicks
              N96872
                Re: Engine Baffling
                Yes my engine is a C85-12 and yes i do have inter cylinder baffles.No i did not modify them at all also i did away with the baffle under the engine and closed up the hole in the front of the nose bowl. it acts like a pressure cowl cools well cht's 315/320 oil temp 200 with the out side air temp 90 deg.
