Flying Taylorcraft in Class Bravo
  • Flying Taylorcraft in Class Bravo
    Has anyone flown into class bravo airspace with a Taylorcraft? I live in Middle TN and am wanting to fly into Charlotte, NC airspace for a landing at a satellite airport.
    Danny
    Re: Flying Taylorcraft in Class Bravo
    As long as you have the required equipment the type of airplane shouldn't be an issue. If you don't have a transponder I doubt that they will allow you in the class B airspace, but it may also depend on how busy they are.
      If it's a satellite airport under the Class B wedding cake you should be OK. I based my non-electrical system Tcraft at DWH which has a tower and is under Houston's Class B. A friend flies his Tcraft from here as well. We just add "negative transponder" to the first departure or arrival call and have never had a problem. If it's a non-towered field you don't need the radio and no one will even know you were there.
      Regards,
      Greg Young
      1950 Navion N5221K
      2021 RV-6 N6GY
      www.bentwing.com
        Danny,
        I live under Class B and am inside the SFRA airspace around Washington DC. I fly on floats, so none of my flights ever start or end at an airport. in spite of all of this, the controllers are great, helpful and willing to accommodate any request that is legal.
        Don't be intimidated by the radio calls or the process. there is absolutely nothing wrong with letting the controller know you haven't done this before, and you could use their help. they will help you!
        Call flight service by phone before your flight. They will give you a step by step list of what to do. Write down all of the frequencies that you will need, you can get them off a VFR chart.
        After your flight, you will be real proud of yourself for fitting into the system.
        Don't be afraid.
        John 3728T
          Danny,
          Don't be afraid.
          John 3728T
            If you need to go into the "B" you need to call on the phone for permission. I remember several years ago where a pilotshared his experience flying into the Class. "B " at San Francisco. He said it was a good experience. And he thought the controller enjoyed doing something different.
            L Fries
            N96718
            TF#110
              I live near the New Orleans Class B airspace. I fly under the veil without talking to them regularly.
              I've flown into the Class B airspace twice by calling the tower by telephone just before the flight (like L.Fries said). One time they gave me a "Special Clearance" number over the phone. It was a four digit number. Then in flight, when I made my initial call, I said that I had "Special Clearance 1234" and they replied "Oh, Taylorcraft, we have been waiting for you." Very nice experience.
              Tim Hicks
              N96872
                Like stated above, just call the tower and arrange it ahead of time. I found that the controllers are quite accommodating and willing to do what they can to help. Just make sure you can navigate the exact route including elevation that they give you to follow.
                Randy Buell
                1940 BL-65 N27504
                1946 C140 N89129
                “No matter how worthy the cause, it is robbery, theft, and injustice to confiscate the property of one person and give it to another to whom it does not belong.” WW
                  I fly under the KPHX class B at surrounding class D airports often. No issues. To go into B you'll either need a waiver or call ahead. Shouldn't be a problem.
                  DJ Vegh
                  www.azchoppercam.com
                  www.aerialsphere.com
                  Mesa, AZ
                    UHM no, I have tried and they just laughed at me. You need to remember to say, "negative transponder, no electrical system." on the radio when making the initial call. I fly in SLC airspace all the time and into class D at OGD, they ask but after a couple of times and they know your N number, they wont anymore. I have also flown into FAI and ANC without a transponder, both class C, they ask and then give you permission. To enter in B but under the veil, you just need to remain clear of the actual airspace. I now have a portable transponder but its not necessary, it may suck but they will communicate and give you grief if they are having a bad day but they have to work you in to the airspace. Tim
                      Thanks guys !
