I'm trying to figure how to run perimeter tape along the trailing edge of the rudder with that light socket ring mount thingy in the way. How did you address that problem? - Mike
Perimeter tape on trailing edge of rudder. The light socket problem
Re: Perimeter tape on trailing edge of rudder. The light socket problem
Tim/John - am I rephrasing this correctly? Cover the socket with an oversized doily leaving a skirt long enough to extend past the tubing. glue in place. When dry, shrink fit. Then apply perimeter tape like you would around a hinge fitting, that is, cut a hole in the tape and let the socket poke thru. glue in place. Correct? ( I can't make anything easy!) MikeMike Horowitz
I would put on the perimeter tape, the one that follows the trailing edge on first then do the doilie which is large enough to cover the ends of the 2 tapes. TimN29787
