What type of set screw in the trim handle, can it be flat? Mine does not look to have an Allen set screw but wont come off. I am trying to get the headliner out to get to the nav/com antenna. It's on a 1982 F21.
Removing Headliner from F21
Re: Removing Headliner from F21
Well thanks for the help. It did have a roll pin above the handle and no set screw or nut (see pic). I love how a round shaft goes into a square holeAttached Files
That sure looks familiar! Just what happens when someone thinks you have to make sure the pin doesn't come out. If it has the right escutcheon plate (one with an inside flange) and pin it can all come apart without tools and WON'T fall apart on its own. You just need to push the plate up against the headliner until you can use a paperclip to push out the pin (which will immediately fall on the floor and roll under the floorboards). When it is put together right is is the virtual definition of simplicity.
