I LOVE Handpropping
  • #31
    Re: I LOVE Handpropping
    When I first got my plane I ALWAYS propped from the front. People would come up and say, hey, you should really be propping from behind.
    At that point I didn't have impulse mags and you really had to pull it through hard. When I started propping from behind it felt weird! Really weird. But now I do it all the time, I fly on skis a lot and I'm scared to stand in front of the prop especially on ice. So propping from behind is my new routine, it definitely took a while to get used to, but I feel much safer now
    • #32
      My BC65 idles at 400 to 450 RPM. I ALWAYS carry screw in Tie Downs, and a properly tied 100 foot rope in the canvas sling. Besides a GREAT tent rope to drape a tarp over, it makes a great thing to have as a survival tool, along with a blanket. my AR-7, 50 rounds of CCI hollow points, magnesium fire starter, a gallon of water, and a really good first aid kit. I sewed hold down straps into the canvas pouch, to hold everything in it's place.
      Brie
      • #33
        Thanks Richard,
        Do you have impulse mags?
        Dave,
        Yes I have impulse mags, which I am sure makes it a little easier. Have you tried propping from behind? If not, I would suggest you try it with the fuel and mags off while someone watches you. You can tell a lot just from the way it feels. But having someone watch you offers another perspective. Maybe you could start out by watching someone else who has been using the technique for awhile. Good luck and let us know your thoughts if you decide to try it.
        • #34
          Originally posted by n6346m View Post
          I agree with "senior". If I had to follow all of Hank's rules, I wouldn't get to fly much. I prefer to prop from the back because I have never seen an airplane (except for turbines) go backwards when they start. The one rule I have always used since I started hand propping airplanes in 1973 is to always TURN OFF THE FUEL VALVE before starting. If things go wrong and you are acting like a wheel chock or hanging onto the wing strut while your airplane goes around in circles or watching your airplane go across the airport or down the lake, it's comforting to know that the engine will stop when the carburetor bowl runs dry rather than when the fuel tank runs dry. As for not curling your fingers around the trailing edge of the prop, I don't know how you can do that. It seems to me that to get enough friction on the front of the blade to pull it through using just the palms of your hands you either need to get your compression checked or you're pushing on your airplane way too hard in the wrong direction.
          I like it, great idea!
          Also regarding the friction needed to to prop, I wonder if using some shooters spray adhesive on the prop or your hands would help?
          We spray that on clothes, mats, coats and rifles when shooting and it helps a lot. It cleans off of your hands easily.
          • #35
            I've been thinking about why some people worry about fingers around the trailing edge of the prop when hand-propping. The only time I can see that it would be a problem is when the engine would kick-back. OUCH !!! That hurts. If you do not have an impulse coupling your magneto timing is advanced and is more prone to kicking back. Impulse couplings not only speed up the magneto they also fire a retarded spark close to TDC and pretty much eliminate kick-back and make the engine easier to start.
            That's why when timing an engine you fire the impulse and go back and set the required magneto timing with the impulse coupling disengaged. When I had my A-65 on my L-2, I had a single impulse coupling on the right Bendix mag and I always tried to start on the right mag. If I tried to start on "both" I could usually feel the left mag firing early in my fingers. OUCH !
            Due to cost, added complexity, reliability and AD issues, an amazing number airplanes have, and only need, one impulse coupling. That's why they make key-start switches that only energize the right magneto when in the start position and spring back to the "both" position when the key is released.
            When starting an engine with a dead battery most people unfamiliar with hand propping usually select the "both" position thinking it will start easier. If they have only a single impulse coupler the mags fight each other with different timing and make starting more difficult and therefore more dangerous. If you find yourself in that situation, be sure that if you have only one impulse coupling to only select that magneto when hand propping.
            Bob Picard
            N48923 L-2B Skis/Wheels
            Anchor Point, Alaska TF#254
            • #36
              It is possible push (or pull) against the trailing edge of the prop without wrapping your fingers around it.
              • #37
                I think we're into semantics here or splitting hairs. If you push or pull on the prop anywhere against the trailing edge, then unless you are using your elbow, something is sticking out on the other side of the prop whether it is your fingertips or part of your palm with the fingers attached on the end. I just went out to my airplane and tried to pull the prop through front or back without touching the trailing edge and I can't do it. I just can't get enough of a grip without part of my hand pulling the trailing edge especially from the backside where the prop blade angles away from you.
                Bob Picard
                • #38
                  I prop start my BC65 standing in front of my prop, with REALLY HEAVY and HUGE chocks that look like they were used on a DC-3. When I do it, I have about an eighth of an inch worth of three fingers of my left hand, hanging of the trailing edge of the prop. I DON'T power the prop for a long distance, I set it up where I "Prop" it from 11:00 O'clock, to 9:00 O'clock.
                  Brie
                  • #39
                    I have never tried to start from behind, but I can see where it would be difficult to impossible to not wrap your finger tips. From the front I can guarantee you it is NO PROBLEM for me to pull an engine through without wrapping the tips. Compression has never been a issue from a 220 HP radial that was soft as a feather (till it back-fired and ruined a good pair of pants) down through my A-65-8 (which was NEVER a problem) to the NASTIEST engine I ever propped, a short stroked, high compression, tiny propped little VW 1600 that would jump out and bite you in a heart beat. That one required BOTH hands, crossed at the hub and a "flipping" motion where you twisted the prop from close to the hub to get enough spin to get her to fire. Not only that, but the little monster spun BACKWARDS.
                    I HATED that little piece of junk. It ran great and worked well but I doubt I would EVER hand prop one again, especially with the nice starters you can build or buy for them now. The Dawn Patrol guys in Kansas City used chain saw engines for a while and I think most have converted to electric drill motors now and use 12 and 18V battery packs to start. I want to figure out a way to use them to start our engines. If a drill motor can start a VW it should be a breeze for a Continental 65. Just got to figure out how to get the torque to the crank without ruining the nose bowl.
                    By the way, I still use my list to start. It can be a pain, but while I was in the Navy in an E-2 squadron we had a Tech Rep walk into a T-56 prop. I will put up with the problems. It isn't something you forget soon (in my case, not in 40 years).
                    • #40
                      Hank,
                      Perhaps someday someone can show me how it's done. I'm not too old to learn something new. However I am just as comfortable propping from the front or the back and for the type of flying I do I just prefer the back, especially when on skis and floats, and besides because you do it with only one hand you only have half as many fingers to lose. Maybe I'm having a problem with the term "wrapping fingers" around the prop. You don't have to have your fingers "wrapped" around the trailing edge to have contact with it with some part of your hand. Even with a perfectly straight hand with all fingers sticking straight out, I still contact the trailing edge with the meaty part of my palm where the knuckles join the palm.
                      Bob Picard
                      • #41
                        Bob,
                        I have seen folks wrap their fingers around at a knuckle I think that is more precarious than a finger tip against the trailing edge. That's all I meant.
                        • #42
                          Fuel off on start-up is something I also always do to.
                          With the door also opened right to the boot cowl, which allows you to instantly reach in & adjust throttle, switch mags or switch off if needed!
                          I also keep a single leather (right) glove in the corner of the windshield for propping.
                          I never used a glove with the old prop but the one I'm using now seems to be much sharper on the trailing edge.
                          46 BC-12D Taylorcraft
                          46 Chief
                          • #43
                            Thank you for this. This never occurred to me in all the years I've been hand propping my plane. I feel a bit silly, since it's such a good/simple idea. I always learn something new everytime I'm on this forum. At my airport, there isn't a whole lot of "vintage" aircraft anymore, and much of what I know about my Taylorcraft, I've picked up here.
                            -Anthony
                            _____________
                            1946 BC12-D
                            NC43501
                            • #44
                              I'll interject here about the fuel 'off' idea. My plane runs for quite awhile with the fuel off. Anything that is going to happen will happen long before the fuel exhausts. Unless, you decide to start on one end of an unobstructed field and at something far above idle. (I know what you are thinking, I have heard the stories and seen the Youtube videos).
                              My situation is a set of hangars across from me and a fence and other obstructions everywhere else. Mine would not run out of fuel before striking something else.
                              You have to have a ritual and stick to it. Every time. No deviations and do not rush. The propping part is easy, it is everything leading up to it that can get you into trouble.
                              • #45
                                Right on Marty! It is all the [I]little stuff[I] that can kill you. I always turn my fuel off also. If the throttle is at idle it takes 30 seconds or so to run out of fuel. But at higher settings it runs out in just a few seconds.
