My dad is building an all wood Fisher Celebrity biplane. He's at the point of making the flying/landing wires. The plans say to use two Nicopress sleeves per end. I say only one is required. I see two all the time at fly-ins on homebuilts and I have always thought it was something builders did as a sense of redundancy but really? As I understand it a properly compressed sleeve will slip/fail well after the cable has failed making two sleeves on the ends kind of silly. Also I have understood that two sleeves may stiffen the wire between the sleeves and be more prone to fatigue in that area.
So... what's the consensus? One sleeve is sufficient? Does two really add any level of redundancy if the sleeves are properly compressed?
