Reporting emergency off field landings to the FAA
  • Reporting emergency off field landings to the FAA
    I stopped by KSHD a few weeks ago talk to my avioncs technician for upgrades in my Bonanza. During our discussions, he mentioned that a customer was flying his Bonanza in for new radios a few days before but had to make an emergency landing in a farmers field due to running out of gas. He also shared with me that the Bonanza pilot later found he had gas but failed to make the proper tank selection. I asked what the findings were from the FAA and was told they were not contacted since there was no property damage and that the Bonanza had been disassembled and trailered back to the owners home field. I then shared with him my off field landing in my TCraft (refer to my off field landing in "gear stop cables" in this forum) and the hassel with the the FAA and he said I did not have to call them since I had caused no damage to property owner. In my case I had four meetings with the FAA from December through February this year with a final conclusion that there were no infractions and the case was closed. This was the second A&P mechanic that told me that the FAA did not have to be contacted unless there was property damage. I thought I would pass this along to others to prevent unwarrented involvement with the FAA if, indeed they do not need to be notified. Would sincerely appreciate any comments on this matter.
    regards to all,
    bob price
    Re: Reporting emergency off field landings to the FAA
    Look up NTSB 830... that tells you what the definitions are and what constitutes what must be reported.
    Ryan
    Ryan Short, CFI, Aerial Photographer
    Former Taylorcraft BC-12D owner - hopefully future owner as well.
    KRBD and KGPM - Dallas, TX
    TexasTailwheel.com
      Incidents: File a report if requested by the FAA
      Accidents: Required to report. NTSB 830 defines
      L Fries
      N96718
      TF#110
        Ryan/ L. Fries
        Thank you both for the information provided.
        I have reviewed NTSB 830 and found it very informative and will pass this along to other aviaiton friends I come in contact with... Knowing what is required can prevent unnecessary "hassels".
        sincerely,
        bob price
          Don't make the call unless someone is hurt. Even then I would not call on someone elses airplane....
