Re: Taildragger tail dragging
When we put c85 on my plane i had a similar thing happen not as bad as you are we had the wrong washers on the engine mount bolts and that let the engine sag so the thrust line was off put on right part an the problem went away. also my tail wheel is 69 lbs and light weight is 777 lbs and like Rob said the pre war are fun.
