We stripped the old fabric off the wings and found three birds nests and one mouse nest.Also found left wing with stamped ribs and the right wing with truss type,can the wings be mixed like this or do we have to find another set of one or the other? Also they were both rib stitched .Haven't fully inspected the spars yet,but if needed what's the best option for spar stock?
Wings and spars
Re: Wings and spars
Hi Mike, and a belated welcome to the Forum!
Others will supply details as to whether the wings can be mixed & matched, and for spar stock , but first count the number of ribs on each wing ... they should be the same (either 13 or 15).
Also check for rot in both wood & metal caused by mouse teeth & urine respectively !!!
Personally I don't like stitching on stamped ribs, because the sharp edge of the stamped ribs could potentially cut the cord, but history (like yours) does not support my reasoning. It may be illegal (in terms of there is no "approved data" for stitching on stamped ribs) , but I may be wrong.
Re: Wings and spars
Got my spar stock from aircraft spruce. Wag aero is now selling ready made spars. My wings were mixed as well. Left was stamped and right truss. I went all stamped to have a uniformed look instead of one using clips and the stitching.Ryan Newell
1946 BC12D NC43754
1953 15A N23JW
TF#897
Re: Wings and spars
Hi Ryan,I'll check wag for spars,do you still have the truss ribs and would you be willing to sell them if we can't find any?By the way I have looked at your restoration photos and what a great looking airplane you have!......Regards
Re: Wings and spars
Hi Robert, and thanx for the welcome, as for history supporting your reason,you may be right after all as we had many stitches cut through when we stated disassembly.Do you know if the clips can be found for the stamped ribs,and is one rib preferred over the other?
Re: Wings and spars
Well the clips (more accurately called Taylorcraft Wire) for the stamped ribs are difficult to find.
I don't think there is any preference between stamped or truss ribs (I have owned aircraft of each type).
But having re-fabricked both types, I sure prefer the Taylorcraft Wire ("clips") over stitching!
Some photos of using the Taylorcraft Wire on my webpage here; note I use the word "clip" to mean Taylorcraft Wire.
This photo might be of interest to you, it is the difference between Taylorcraft Wire and "Martin Wire" sold by certain aviation houses. Note the difference in the shape of the barb and the spacing between the barbs.
Re: Wings and spars
Dalton,
If it comes down to it, there is a lot of info on here about modifying the common 'Martin Wire' that is no longer available commercially. It involves placing a 'Z' bend in it to shorten it between the holes. Use the search function and you can find it. Welcome and good luck!!!Cheers,
Re: Wings and spars
Originally posted by mikeg View PostCheck your FAA STC listings guys, there is an STC for installing PK screws (similar to Fleet/Aeronca) in the stamped ribs. Did one once, many years ago.
Mikeg
Larry Wheelock TF671, Stinson 108 N584LW, BC12D N96179
Re: Wings and spars
Mikeg
Re: Wings and spars
Hey Guys,thanks for all the great advice and sources,what a great forum here! We have decided to replace the spars in our T,seems like with 60 plus years and over 50 on floats with original spars, might be time. Are any drawings available for the wing assembly?I've done a couple of champs and a cub and found these dwgs. to be a great help.
Re: Wings and spars
Don't trash those old spars, even if you don't plan to use them for your plane. The older Spruce was tighter grain, denser and stronger than what we can usually get now. If it is good shape, old stock is actually better than new. Even if it has bad spots it is still very valuable to make clip wing spars or aileron spars. I NEVER throw away old spar material. If nothing else I will rip it up to build furniture or models. I have seen people burn some really beautiful old wood, just because it was old.
Re: Wings and spars
Hi Hank, I won't trash them,understand the value .these spars have the Taylorcraft name plate on them so I know they are old,but the plywood doublers are delaminated from the butt and I suspect there me be some issue with the wood underneath. I'm not familiar with the clip wing mod,so would they still be of some use even if the butts are bad?Do you know where I can get some wing drawings?.......regards Mike
Re: Wings and spars
The ply can be replaced if the wood underneath is OK. When you do a clip wing you trim off the root end anyway and have a fresh root end. As for the aluminum stick and stamped ribs, I used to think the stick ones were lighter but was told that isn't true. The stamped ribs stand up to damage MUCH better (like when someone puts a gas can on the wing to refuel) and the only real reason to use the stick ribs is for originality. If the plane is post war there is NO reason to use them unless you like to rib stitch, in which case you might have more mental problems the the majority of us (I am one of the total nut cases who LIKES to rib stitch). If you plan to rebuild a wing save the stick ribs for the screwballs who have pre-wars and want to keep them factory original (like me) and you can get trades for stamped ribs to build up the new wing.
