What is the best way to break in a new engine with steel cylinders. I always thought you wanted to baby steel cylinders by running at a lower rpm as much as you could, and run chrome cylinders as hard as you could. What say you engine overhaulers???
A&Ps Opinion on Engine Break In
Re: A&Ps Opinion on Engine Break In
Marty,
That has a lot of interesting info in it. But it doesn't say anything about after the second hour of operation. It just says during the second hour to operate between 65 & 75% power. I always thought it took 25 to 50 hours to break in an engine.Richard Pearson
Richard, I have no clue about engine break-in. I was just posting the link that the guy above me said to Google.Cheers,
Good question Richard,a big investment and you want to get it right! New cylinders going on mine in a few days I have been reading and listening to different opinions. I will be talking to Mad Mike (engine specialist)here in the valley some more before I fly behind the new top overhaul for the first time.
JimJim Hartley
Palmer,Alaska
BC12-D 39966
Richard,
I'm so disappointed. I thought you were a regular visitor to my website, whereby you would have come across the definitive Continental "break-in" procedure.
Here's the link: Don't Baby your engine
Take two aspirin, say three hail mary's and give your dog an extra treat.
Robert,
I started my pentance with the three Bloody Mary's, I was going to give my dog a treat, but I fell down and busted me bum. That reminded me to take the two asprin. I had seen that document before, probably on your site. But I had forgotten what it said. NOW I remember!
Cheers!Richard Pearson
No matter what, DO NOT BABY IT!
Richard,
Rings need maximum pressures to properly seat. Watch temps, yes, use mineral oil, yes, on an A65 with fixed pitch, climb power is full power. Level at a safe altitude and circle the landing site always within gliding distance. Intermittently run it wide open and then back to not less than 75%. Fly for an hour. Land, let it cool, check everything over. Do the same again a few times and it will be broken in.
Larry Wheelock, BC12D N96179, A&P, IA
Richard,
Light it up and check for leaks. If it's not leaking taxi it out, run it up, and fly it. Full power climb to 3000ft, don't exceed max temps. Throttle it back, this is where it will break if it's going to, oil temp will stabilize or even drop a smidge. Back to full power and climb to 5000ft, oil temp will return to earlier climb indication. This means you're able to control your oil temps. Don't sweat the pressure, 15-40 at rated power is good. Most people try to keep the pressure too high, this just wears out the pump shaft bores.
I can't stress enough the need for proper baffling. If it's not tight fitting and sealed properly you will cook the top end of this little engine. It's not going to blow to smithereens but you'll be putting cylinders on every 300-500hrs.
EO
At 3000', I would be 1500 below the surface of the gound!
EON29787
Yeah, like that is the western 1/3 of the United States!
Originally posted by Edwin Otha View PostIn your case the only way to properly run in your engine is to trailer it to a lower elevation. Everyone knows that you can't break in an engine at high altitudes.
EON29787
