I messed with "painting" the letters with a red magic marker. Not pretty, but that part will take a steady hand.
Two different types of sheet. The bronze is 30 ga., the bright brass is 36 ga.
The brighter stuff takes detail better but will be more fragile and prone to denting unless the back side of the embossing is filled with solder or glue or something like that.
I have the capability to make embossed placards from just about any artwork you can supply. The speed limit placard was copied from the L-2 print.
Josh Brehm
Winterville, NC TF#910!!
Ship #1705
) After about 20 coats on and taken off, I am down to the last time, I hope. Last week the last wet coat lifted some of the old coat. But I am on the down hill to finish by spring.
