I finally got the 4 piece flat panel templates together in my guest bedroom along with the tracings of the metal parts. I heard from Bob Coolbaugh, Mike Jones, Frank McQuaide, Warren Brown, Carl Carlson and Larry Lyons so far as wanting copies. No cost yet, but I will make one set and post my cost before making copies for everyone.
If anyone else wants them (or if any of you guys no longer want them) let me know so I can get an accurate count on how many copies to make. Please DON'T send me messages through the Taylorcraft group, I keep exceeding the limit for messages! You can reach me at:
aeroapplications at yahoo dot com
I would HOPE you guys can figure that out!
My COX email may not be active much longer, their service keeps failing and they are on their last warning before I change providers, so use my old company address above and I will convert that account to Taylorcraft use until I can set one up just for Taylorcraft stuff.
Please send me your addresses and phone numbers if you still want a copy of the drawings (these will not actually be "drawings" because of the size, but tracings of my parts). DON'T cut expensive plastic directly from the templates! It probably WON'T fit your plane right. Each plane was a little different and you are going to need to "massage" the shapes a little. I will walk everyone through the process here with cheap plywood and cardboard. Be prepared to waste some Plexiglas! This does NOT work the first time. Hopefully you will all get your Windshields (the front piece that is the EXPENSIVE one) done professionally. I broke a BUNCH of side windscreens trying to bend them and fit them to the front of the rib.
You should also be prepared for a few blisters and burns from heating the Plexi. You have to get it HOT to bend it without breaking. It is a great summer job when your hangar is so hot you don't want to go inside!
