Anyone have a nice LH doorstep and/or prewar door handle assby for sale?
WTB: LH Step and Door Handle
Re: WTB: LH Step and Door Handle
Mike,I have the handles and parts that fit the tube metal doors if you want to make copies. The outside handles are teardrop shaped with a square shaft that goes through teh hole in the door. The end is threaded for an acorne nut and a hammered piece of flat steel with a square hole is the inside handle and latch.
Pretty simple to make if you don't mind casting the teardrop in resin instead of metal.
Here are the pics of the handle and latch that I need. Thanx.MIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
Mike,
You might try Wag Aero for the step-They said several months ago they would start producing them and they show to stock them now in the on line catalog.Last edited by Buell Powell; 05-12-2010, 12:06.Buell Powell TF#476
1941 BC12-65 NC29748
1946 Fairchild 24 NC81330
Hi Mike,
I have a LH step for you for $30. And I have an NOS outer handle with the original tag still attached. The inner latch handle with this is for a later pre-war ship. It does not match what you have but matches two others that came off my plane. Maybe your inside latch style was made just for the '38 or someone made it up for a replacement. In any case, if you want that entire assembly I'll take $30 for that plus shipping. Sound fair to you?
Regards,
Glen Brodeur
TF #42
Putnam,CT
I understand- just thought I would let you know in case you couldn't find or make one. I noticed they have landing gear now too(looks like by the number for straight axle) -not inexpensive either but really good to know they are available.Last edited by Buell Powell; 05-12-2010, 15:55.Buell Powell TF#476
