Old front struts wanted
  • Old front struts wanted
    Tribe- I'm looking for an old set of BC12-D front struts for use on my clipwing. I will be cutting them open so the inspection will be easy- I'll seal them after I shorten/ weld for use on the clipwing. I have a good set of rear struts- just need some front ones. let me know what you have- close to NC is better!
    Eric Minnis
    www.bullyaero.com
    Clipwing Tcraft x3
    Re: Old front struts wanted
    This begs the question. can existing struts be sealed to meet the AD requirement? - MikeH
      If you can prove they have no corrosion and you can get the FAA to accept it as an alternative method of compliance, I don;t see why not.
        Very reason I collect old struts from all anitque airplanes. Unfortunatley I don't have any good "B" struts but i probably got enough other good struts from other planes that could be cut down
          Thanks for all the replies- I think I have found some locally to use.
          Eric
          Eric Minnis
          www.bullyaero.com
          Clipwing Tcraft x3
