Looking for LH aileron, hinge brackets, bellcrank
  • Looking for LH aileron, hinge brackets, bellcrank
    For a BC-12D which was swallowed up by a dust-devil, need a few parts for repair:
    • LH aileron or 2 aileron ribs
    • outboard hinge bracket (1215 cast, 1553-2 assy)
    • bell crank horn (1210 cast) that attaches to the center hinge
    • OR the whole center hinge bracket/bellcrank/brace assembly (p/n 1553-1)
    • Or a whole LH wing if located in California
    let me know if you can help!
    I will check my parts for the two aileron ribs.
      I have a left aileron that I was going to rebuild that is available, however, if you dont want to rebuild one than this is not for you. Also many aileron nose ribs and one center hinge. Enough wing ribs to build a wing.
        Does the center hinge you have include the top horn/bellcrank? That is the cast (magnesium) piece that broke for me.
        I think I can rebuild the aileron that I have, need to replace the trailing edge and maybe 2 ribs just inboard of where the tube bow meets the aluminum trailing edge. [rib 2-3 from outbd]
        But also looking for a complete aileron that I can pop on to move the plane sooner than later
          I do not have a bell crank for the center hinge. I have the trailing edge and the 2 ribs. Let me know if you decide to rebuild and are interested in the parts.
          Rich
            Yep I’d like them! Will send you a message.
              Hello all,
              Still on the lookout for an aileron bell crank horn (1210 casting) that attaches to the center hinge​. They are LH and RH side interchangeable.
              any help is appreciated!
                I think there was someone on the Taylorcraft FB page recently with similar?
                  Indeed, but having trouble actually getting hold of folks over there. It’s hit or miss
                    Found a bellcrank! Thanks to everyone here for the help too. I’m amassing some extra parts in case anyone needs any for the future : )
