Wanted: A65 Cylinder 0.015 over
  • Robert Lees
    replied
    Re: Wanted: A65 Cylinder 0.015 over
    Cylinder has been delivered to Oregon.
    Update:
    I found a cylinder at Harrison Engines http://www.harrisonengine.com/ (nice people to deal with, so far!)
  • mikeg
    replied
    Back when I "worked" for a living, they did all my cylinder work. Good folks, good work.
    Mikeg
    NC29804
  • Edwin Otha
    replied
    Best guy's on the West Coast are, AirWest Engines in Hayward, CA and Randy Thompson of Thompsonair in Anderson,CA near Redding.
    EO
  • Ryan
    replied
    Update:
    Rob both our Pacer and Tvraft have cylinders from Harrison. I think you are in good hands
  • Ryan
    replied
    Update:
  • Robert Lees
    replied
    Update:
  • astjp2
    replied
    If you want some sent to Gibson and pay for the rebuild I have several. Tim
  • Guest
    Guest replied
    Speaking of yellow tags, what FAA form is a Yellow tag? I had 4 cylinders that had yellow tags on them and assembled the engine and it seized when it got warmed up. cooled down and it would run. Pulled the jug, tagged .015 and it was only .010. Just because it has a tag does not mean its right. It only means that the cylinder has a piece of paper. TIm
    Checking the ring end gap during assembly should have revealed that. Did you see any issues with the end gap?
    The gaps/clearances should be checked during assembly.
    Tags and factory forms are mere paper. Plasti-gages, feeler guages, micrometers tell the real story.
  • Robert Lees
    replied
    I left a message, Mike
  • mikerice
    replied
    Hi Robert-
    I contacted Harrison Engine Services in Indiana www.harrisonengine.com
    He can weld on A65 A75 cylinders. He has one serviceable .015 cylinder that just came available for $450. Talk to Darryl, but you may have to reach him Monday.
    Mike Rice
  • Robert Lees
    replied
    Originally posted by mikerice View Post
    We have 3 cylinders and pistons that we removed and replaced with the Gibson Aviation units. We kept all three, because the A65/A75 cylinders are so damn scarce. I was hoping that a FAA Repair Station would come up with a welding procedure to put the cracked cylinders back in service.
    Our cylinders should be A75, and they are .015 over. 2 were determined to have cracks, but one was rebuildable (needs hone and valve job). I have to go the hangar to check them out, and see if I can identify the good one out of the three! I can also take a look a the pistons/rings. We are kinda flooding today in Central Texas, so not sure when I will get to the airport. Probably Monday due to schedule.
    Mike Rice
    That would be helpful Mike, thanks.
    Are cylinders generally hard to find in the USA?
  • Robert Lees
    replied
    Yeah but you may have misunderstood, it was to balance his check book!
    I'm sure that's tongue in cheek, and I don't mind. But I have an aeroplane 7000 miles away from me that needs fixing. I've asked him to fix it, and between us we need to find a cylinder.
  • mikerice
    replied
    Mike Rice
  • Guest
    Guest replied
    Tim, the A&P has quoted to me that he needs to weigh the pistons for balance purposes. He seems to know what he's talking about.
  • Robert Lees
    replied
    ....Just thought I would muddy the water more for you
    Yes. You have. And Yes, all the pistons are the same.
    I'm a lowly Taylorcraft owner looking for a cylinder. How hard can that be? I'd find one in a flash here in the UK, but I assume there would be more available in the USA, where all these darn cylinders were made.
