Need cd's
  • Need cd's
    Hello, Finally have gotten approval to post. I have L2 serial #5307 with swivel seat and speed brakes still intact. It is in pieces at this time and I would love to get a set of CD's so I can start the process of putting it back together. Also, if anyone has struts available or knows where to get any they are missing on this plane.
    Thank You
    Bill
    Re: Need cd's
    univair used to build them. Not sure if they still do or will.
      Re: Need cd's
      Bill,
      I will have the struts off my L-2B soon as I am going to recover the wings this winter. If they are the same as the "M" I can take them over to Airframes Alaska and have them duplicated. Let me know if that is an option for you.
      Bob Picard
      N48923 L-2B Skis/Wheels
      Anchor Point, Alaska TF#254
        Re: Need cd's
        Originally posted by n6346m View Post
        Bill,
        they are the same. only difference is the jury struts
          Re: Need cd's
          Bill
          i just sent a flash drive of the cd's to jamie at kelly aiport south of denver, he should get it today or tomorrow. I called him, his number is on the next string after your "Need CD string".
          He mentioned sending the flash drive on to someone else after he copied.
          you might give him a call and see if he can send it to you.
          otherwise i can get you a copy, if you give me and address
          thanks
          paul
