Lycoming crankshaft oil seal installation
  • Lycoming crankshaft oil seal installation
    Lycoming crank nose seal info, also works on Continentals!
    Re: Lycoming crankshaft oil seal installation
    and always use genuine seals. The durometer of the rubber is softer of superior seals and would occasionally leak around the shaft. it was worth the extra cost to do it once.
