Weight & Balance
  • Weight & Balance
    Guy's I'm brain dead, when figuring weight & balance on a 1941 BC-12 is the oil included in the empty weight or do I add it in?
    Thanks, David DeBerry
    Re: Weight & Balance
    included
      Oil is NOT included in the Empty Weight.
      In 1978 regs allowed oil in be included in EW.
      Generally mfgs.then used the term "Basic Empty Weight".
      Are you checking W & B for a flight or after weighing?
        I am just inquiring for my information. I can't seem to find any litarature that gives me that information and I so thank you for your replys. Now I'm still kinda confused with a nay and a yea but I'll just keep figuring it in.
          AC 43.13-1B has a W & B section.
          Oil, Useable Fuel & Useable Oil & Baggage are considered "Useful Load" items.
          If someome is familiar with a newer aircraft like a Tomahawk the W & B system is "post 78" & oil is part of Basic Empty Weight.
          When you weigh an aircraft for W & B purposes the standard is No USEABLE fuel or oil.
          RESIDUAL fuel or oil that can't be drained in part of the Empty Weight.
          Often it is easier to fill fuel & oil ; weigh aircraft & then mathematically subtract the effects of fuel & oil.
          Better than trying to estimate 3/4 fuel & 3 1/2 qts oil.
            Magman thanks so much.
              shows how long since I have done a wb. I don't consider oil useable. if I am using that much oil, I have bigger problems.
                Actually; if the oil is UNUSEABLE you really have BIG problems!
