Ever since picking up 'Scarlett' I wanted to put a set of pretzel yokes in her like I had in my original BC-12D.
John at Skyport Services is assisting me in doing so and asked that I pull the current yokes and rods out to see how everything was attached and what kind of mounting holes were present. My late, late model yokes were bolted on and i know the pretzel yokes utilize a tapered drive pin.
I think my current control rods have been sawn off already as the yokes were resting up against the instrument panel. One is 17 13/16" long and the other 17 5/8" long. (One also has some rusting so I would like to replace them).
-Does anyone have a stock one around to measure or know the stock length?
-These are 3/4" diameter rods, does anyone have a recommended source for this material? This appears chromed, does it come that way or do you have it chromed? (I believe Rob Lees utilized polished stainless??)
Thanks for any help you can provide!
