Fuel line route?
  • Fuel line route?
    Just where is the proper placement of the fuel line to the wings?
    Up inside of door post but then do you go out around the top of the post under the wing mount, or do you squeeze in between control cable, & at top of door post to come out inside the cabin? There's sure not much room to cover fuel lines that way but I'd like to put wing tank fuel valves inside the cabin above the door.
    Sometimes I think it sure would have been nice had I disassembled this project!
    It like a thousand piece picture puzzle with no picture
    46 BC-12D Taylorcraft
    46 Chief
    Re: Fuel line route?
    Does this help?
      Yes, seems clear enough
      Thanks
      46 Chief
        That's just like what was in my 41. The 41 had the control valve under the panel. The 45 was the same except the control valve was at the wing tank instead of by the main. I like that better since a leak in the tube from the wing tank can be stopped by turning off the valve.
