Our 1941 BC12-65 Tcraft is being annualed for the first time by the local A&P. He is concerned about joints in the spar. See following photos. Our spars are made from what appear to be three or four individual members glued together. The concern he has is that the joints appear not to have been sanded smooth after assembly. Because of this he is unable to determine if they are still sound. The joints look pretty much the same for the full length of all four spars with one noted exception. In the third photo just under the text “crack parallel to joint” there is just that. This was also observed in the same photo just to the left of the tin piece. This was the only location were this type of crack was observed.
Is a joint like this normal? If not, is there a way to check the integrity of the joint by sanding a spot down, or something else short of taking the wing apart? Ideally if someone is familiar with this and would be willing to have a discussion with our A&P regarding I would be happy to set up the call for this to happen. However, any sharing of experience with a situation like this would be appreciated.
Blake
Blake
