I recently acquired a B12-65 with a damaged right wing, and the leftwing looks like it is original. I plan to rebuild both wing. I appreciate any advice you can give me.
My first question has to do with corrosion proofing my ribs. For weight saving reasons I would like to strip the ribs and alodine them. Is there any reason that this isn't a good idea? One wing has bare aluminum (apparently the way they were made, the other has painted ribs). Is it ok to alodine them?
Also, does anyone know a source for the folded aluminum "T" stock that the ribs are made of? I saw a photo sequence of a restoration of a BC12-65 online where some of the ribs were replaced with ribs formed from a flat sheet; looks like they came from a later BC12-D. Is it ok to replace damaged "T" ribs with the later sheet ribs?
