Engine Baffles-Internal
This topic is closed.
  • Engine Baffles-Internal
    Does anyone have a drawing showing the installation of the internal baffles for a BC 12-D? My A-65 has a narrow aluminum channel resting on the cooling fins spanning between each bank of cylinders with a hole which takes a small bolt to secure the internal baffel located below/between the cylinders. There are two baffels shaped like a "V" and two others with circular shapes with small coiled springs.. Would sincerely appreciate any information that could be offered..
    bob p
    N96323
