Going to the gang one more time for assistance:
Our '39 BL/BC65 was Forest Green fuselage with International Orange wings. As we've stripped off layers in the rebuild, it appears this was its original paint, so back on it will go. What we don't know is how the trim paint was applied to 1939 T-craft.
Would the horizontal tail surfaces have been painted to match the wings in Orange, and the vertical tail match the fuselage in Green? This is what the old b/w photos seem to indicate. Or would the entire empennage have been green?
We know there is a green leading edge stripe on the orange wings, standard Taylorcraft. What we can't determine is whether there is a corresponding stripe wrapping around the horizontal tail leading edge. Also, is there a leading edge stripe on the vertical fin? All these leading edge stripes appear to be present in some of the b/w vintage photos, but absent in others. Is there someone out there who has researched the paint patterns for the pre-war BL/BC's and wishes to kick in some advice??
Anyone ever seen a dark green and international orange Taylorcraft? This plane flew until '54, has been parked ever since. It had a white layer doped over the green on the boot cowl, but the wings and tail were uncovered, with only traces of orange in obscure places. There is no mention in the logs of a recover or a repaint, so we are anticipating these colors are original.
Another Problem Area: In the bucket of parts labelled 'tailwheel', we find several questions. The Taylorcraft logo steering fork and the solid 6 x 2 tailwheel are present. There is a tail spring set, 1 1/4" wide, with a "U" shaped reducer plate to make the narrower springs fit the 1 1/2" shoe plate in the tail wheel. We know these came off our bird and they are in perfect condition, but the gang here says the springs should be 1 1/2". What do we have here?
Along those lines: There is no tail spring bracket for attaching the spring at the tailpost fitting. It looks like it should be a modified "U" shaped bracket to fit up the spring sides with ears on each side for the attach bolts. It is an easy fix if that's all there was. The problem is in how the spring was cushioned at the tail post bracket. There are three little nibs sticking down from the bracket. They appear to have been designed to hold a rubber bumper in place, which would make a lot of sense. We were considering wrapping the entire spring set in rubber at the attach point, trapping the rubber in place with the "U" bracket. What did the factory do to buffer the spring set from the tail post?
Is there a beacon of light out in this desert of unknowns? I'm getting to know how St. Exupery must have felt when he was posted as station manager at Cap Juby in the Western Sahara! Wandering in circles in the dark, searching for downed air mail pilots, dodging bullets from hostile tribesmen. Well, maybe it's not that bad here, but it really is like having sand in your drawers on that long drive back from the beach!
