engine cowlings
  • engine cowlings
    What is the history of the engine cowling on a 1939 BL or BC-65? Was the engine enclosed inside the cowling or did the cylinders stick out?
    Re: engine cowlings
    All A and B models prior to 1940 had open cowls with exposed cylinders. In 1940 and 1941, the "Deluxe" model had a full cowl, while cheaper versions retained the open cowl. Full cowling was exclusively used post-war.
    NC39244 '45 BC12-D S/N 6498
      Re: engine cowlings
      where can I find plans or drawings for the open cowling?
        Re: engine cowlings
        The open cowl is fairly simple to make if you have a nose bowl. I think I could come up with some rough patterns for a BL cowl flat pieces. Getting a nose bowl is a little harder. Tom
          Re: engine cowlings
          The way I understand it is; the firewall/ boot cowl is different between open and closed cowls. The closed cowl firewall is wider than the open version.....change 1 thing change 10!
          20442
          1939 BL/C
            Re: engine cowlings
            thanks for info guys. If any body has pictures or drawings that would be great.
              Re: engine cowlings
              e-mail me direct , we have cowlings here at Barber Aircraft. [email protected]
