Hello Folks,
My project is a 1940 BC-65. I saw the recent post concerning control stick lube. My rudder pedal assembly had no brass bearing straps installed when I removed them for restoration. My Parts Price List doesn't list any bearings for the rudder assembly. Should there be brass bearings in the rudder pedal assembly? If not, does anyone know why bearings are used in the control column assembly but not in the rudders?
Should I use tube seal oil to coat the insides of the fuselage tubes?
