Restoring a BC12-D
  • #31
    Re: Restoring a BC12-D
    Hi all does anyone know where I get find info & pictures on installing seat sling?
    Steve
    • #32
      Try this thread
      http:// http://vb.taylorcraft.org/sh...ght=seat+sling
      • #33
        Hi all, Does anyone know the sizes or have a print of the Jury Struts? Looking for the Shape, width & length and over all length (center of hole to center of hole)
        STEVE
        • #34
          Hi All does anyone know how much the wheels can be toed out / in ect. Also how do you change it
          • #35
            I toe in 1/8" at 18" forward of the axle. You also need to use a plumb bob and get the centerline of the airframe off of the center of the prop and the tail wheel. I used a big piece of 1.5" schedule 40 pipe, hold the airplane down and reef on the gear until I got it where it needs to be. I have done this on 4 airplanes now and they all track nice and don't want to dart off the runway when you land. tim
            • #36
              Thank you for the info
              • #37
                Hi all, Installed the wings and can not get the wash (1 5/16") out of the left wing, The strut adjustment is all the way in! The Struts are new from Univair Aircraft. Does anyone have any suggestion?
                Thanks Steve
                • #38
                  Hi All, does anyone know how much travel the landing gear safety cable allow the gear to drop?
                  Thanks Steve
                  • #39
                    Thanks Steve
                    Hi Steve, the limit should be to stop the gear before it strikes the lift strut, saving you many dollars, wish you the best, gary
                    • #40
                      Thank you
                      • #41
                        Hi Steve, If you search using the terms "safety cable" you will get a number of threads on this topic.
                        This thread has photos and lengths discussed as well as a template to make a cable: http://vb.taylorcraft.org/showthread...t=safety+cable
                        I might suggest that length be much shorter than letting the gear collapse almost to the strut. The wing tip will be on the ground long before that, which is what must be avoided as well as keeping the prop well clear of the ground.
                        Since you are in re-assembly process, as a test before you put the bunees on perhaps you could report back on how much the tip & prop drops when just supported by the cable length as described in the previous threads. It shouldn't be that much.
                        Mark
                        Mark
                        1945 BC12-D
                        N39911, #6564
                        • #42
                          That's right Mark, forgot about the wingtip first, I have a board with pegs on it from an article long ago, just replaced my cables and lowered it down to make sure they were the right length, and Steve I sent you a PM, gary
                          • #43
                            Hi Gary, did you happen to measure how much it lowered the wing tip? It would be good to know if you did please.
                            Thanks, Mark.
                            Mark
                            1945 BC12-D
                            N39911, #6564
                            • #44
                              Thanks, Mark.
                              I just looked at the tip and the gear, seems like the tip was still between 1 1/2 and 2 feet off the ground and the gear was a couple hands away from the strut, all will be well as long as you don't get into uneven ground or a ditch, gary
                              • #45
                                Hi All, Safety cables diameter, 3/16 or 1/8"? 3/16 seams to be on the larger size
                                Steve
