BC12D fuselage stringer structure quiz
  • BC12D fuselage stringer structure quiz
    The photos below show a view familiar to all who have looked down the inside of the fuselage of their B model Taylorcraft.
    Take a look at the stringers (highlighted with yellow arrows). Note anything of interest? :rolleyes2:
    Re: BC12D fuselage stringer structure quiz
    Looks like maybe 5/8 tubing with light surface rust?I have found some weird and bizarre things in old airplanes over the years.
      Must weigh a TON!!!
      Big question is WHY?
        What Hank said!!
          Indeed it's all steel tubing, thickness unknown, and it does weigh a ton. Empty weight about 900lbs. We wondered why the cg was so far aft, and now we know!
            Bob. Technically 900 pounds is approximately a quarter ton. :ass:
              This aeroplane is in England, Terry. We use a proper ton 2240lb.
              For all our differences, I know that the English pound weight (lb) is the same as the US pound weight (lb) both being 16 oz avoirdupois [French influence].
              A bit less than a quarter ton, Terry.
              Now don't you get me going on fluid ounces.
                I am missing something. The last i knew 2000 lbs was a ton in the U.S.A.. 900 lbs would be almost a 1/2 ton. What am i missing? A 1/4 ton would be 500 lbs. where i went to school.
                Marvin Post TF 519
                  "Weighs a ton" is just an expression when it weighs a WHOLE LOT more than it should.
                  I am assuming you didn't forget the ;-)
                  Hank ;-)
                    Enough with the jokes!!
                    What is that stuff
                    looks a lot like... (heaven forbid)... electrical conduit :hammer:
                    46 BC-12D Taylorcraft
                    46 Chief
                      Or water pipe!
                        That one must have been built by a steel salesman. The only thing missing is the corrugated steel covering.
                        Marvin Post TF 519
                          Like this?
                          TF #1030
                            Well the one in the picture may have taken some ground roll to get into the air but she should have been tough. I wonder if Mr Stout was involved in the making of this airplane?
                            Marvin Post TF 519
                              The only remaining Hamilton H47 Metalplane, unrelated to Stout/Ford, but looks almost exactly like a single engine 2/3 scale Trimotor.
                              NC39244 '45 BC12-D S/N 6498
