Re: Airworthiness Directive Concerns 2007
If this AD is going to require that all Tayorcraft struts either be replaced or have expensive testing every 2 years I would think that if a large number of T/craft owners went together and submitted bids to Univar,Wag-Aero, Aircraft Spruce, and anyone else that could supply the struts for a very large order we should be able to bring the price to within reason. Also we should be able to have them made to the original size-sealed and prehaps made from thicker steel or aluminum (I have original aluminum struts on a Fairchild 24). The Fairchild struts are also open on both ends so moisture can't acumulate and you can see inside the struts even when they are installed on the plane. Also to help with the shipping cost a number of struts could be shipped to one location for those that are in that area. I would much rather keep the struts that I have because like probably every one else I checked them very carefully and sealed them with tubeseal before I installed them and keep my plane in a hanger but I don't like the idea of having to do all the testing and thought there may be a way to help with the expense. Just an idea
Buell
Buell
